I have a Nokia 7610. I have added a few new applications and they all just appear at the bottom of the menu screen.
It is now a bit painful to scroll up and down to find what i want.
Is it possible to put the icons for games in say the Games folder (which is currently empty) also can I create my own folders here (on the menu screen) and move other apps to them.
boakesm wrote:I have a Nokia 7610. I have added a few new applications and they all just appear at the bottom of the menu screen. It is now a bit painful to scroll up and down to find what i want.
go to the icon(s) in your menu.
press options
you can then select MOVE to move within the top level of the menu
or MOVE TO FOLDER to put it in a folder
you can also create new folders in that menu too
Thanks for your help, obviously I now feel stupid as it was so obvious.
