Can't Write Sms Anymore (6670)
2 replies · 2,137 views · Started 25 May 2005
I really need help! my 6670 can't write sms anymore. when i try to write sth, only numbers appear. i deleted some "suspicious" applications but the problem is still here. the remaining apps are: harry poter-kamasutra-bounce-frozen bubble-taptatop- FExplorer-mobile media player-rocko ban-extreme roller. please sb give me help!
Usually the culprit is WildSkinz. With that one, if you had it and already uninstalled it, reinstall it again, reboot, disable it, reboot, uninstall, reboot (just simply uninstalling it without disabling it first is not enough).
N/A wrote:Usually the culprit is WildSkinz. With that one, if you had it and already uninstalled it, reinstall it again, reboot, disable it, reboot, uninstall, reboot (just simply uninstalling it without disabling it first is not enough).
thanks a lot dude. i'll try it. thanks
