Nokia Lifeblog Question
8 replies · 2,092 views · Started 25 May 2005
Ok so I have the lifeblog application on my 6630.
I use a Mac mainly (dont get me started on the isync issues) so I will just be using lifeblog its self to post to my typepad moblog.
The think is for some reason it isnt automatically finding all of my pictures I take and I keep having to import the images using the lost image option. Am I doing something wrong here?
all input much appreciated!!
Meta wrote:Ok so I have the lifeblog application on my 6630.
WHERE are the pictures ? In your phone ? Or have you moved them to you PC already by some other means ?
manta wrote:WHERE are the pictures ? In your phone ? Or have you moved them to you PC already by some other means ?
They are just on the phone not moved them at all. It locates txt messages no problem and adds them to the timeline just not the pictures.
I think I remember when I installed lifeblog on the phone, (or maybe it was the first time I opened it) being asked if I wanted lifeblog to run on startup. I said no because the less things running the better as far as I'm concerned. There is no option to turn it on from within the app. I would suggest reinstalling it and see what happens.
Mufty wrote:I think I remember when I installed lifeblog on the phone, (or maybe it was the first time I opened it) being asked if I wanted lifeblog to run on startup. I said no because the less things running the better as far as I'm concerned. There is no option to turn it on from within the app. I would suggest reinstalling it and see what happens.
That's right Mufty, you need to do this:
[list=1]
[*]go to app manager and uninstall the app first. this is important. (don't worry, it will leave all the database and stuff on the phone)
[*]reinstall lifeblog.sis (make sure it's the one for your phone from www.nokia.com/lifeblog)
[*]during installation, say YES to the startup question, otherwise it won't track your new photos and messages
[/list]
and away you go!
Ok sorted I think....its now decided to do it on a regular basis so not sure what it was.....I did set it to startup on install so maybe it got upset or something lol.
You can use lifeblog without typepad using the PC application to collect all your photos etc and then do what you want with it. Just be aware though that the PC application will delete the content off your phone when you sync unless the items are marked as favorites!!!
Personally I won't be using the software as I mainly use a Mac and there is sadly no software for the Mac....allways galls me considering Nokia use Macs all the time in their images for promotion etc....
You can setup lifeblog to post to a flickr account or a moblog.co.uk account for free. There's a monthly limit on the flickr account (you can upgrade to pro account to have unlimited uploads) but in flickr you can set it up so that your lifeblog posts are automatically posted to another blog. Bloggger for example. It's only for pictures tho. No video or sms..
If anyone else has a better suggestion on this I'd be interested to know too.
Mufty wrote:You can setup lifeblog to post to a flickr account or a moblog.co.uk account for free. There's a monthly limit on the flickr account (you can upgrade to pro account to have unlimited uploads) but in flickr you can set it up so that your lifeblog posts are automatically posted to another blog. Bloggger for example. It's only for pictures tho. No video or sms..
You could allways set up a server yourself if you host your own blog...I havent looked into this and sadly the only way I can use tyepad or flicker is to pay the shocking charges that Three want for emailing. As they don't allow access to external servers I can't use the lifeblogs pure settings which is a pain.
