Can't Get full screen wallpaper in 6620! Help!
1 replies · 2,375 views · Started 25 May 2005
Hi, I tried to change a wallpapers by going to themes-->theme1-->edit-->wallpaper, and selected a 176x208 image. However, when set as wallpaper, this image is reduced in size such that it fits below the clock and oplogo. I want to have this image full screen, without editing the theme in theme studio. I'm ready to use mbmwhizard or anything else, but not theme studio (some java issues in my pc). can anyone help me??
Sorry if this message is in the wrong place.
Thanks,
Harsh
The wallpaper is always 176x144 pixels no matter what.
If you want a full-screen background, you have to use a theme background for a theme (must be changed with Series 60 Theme Studio app from http://forum.nokia.com/ on a PC when you create/edit a theme, and cannot be done on the phone).
For the Java issue on your PC, make sure you install the version of the Java Run-time Environment (JRE) that Series 60 Theme Studio requires, and not any other version (you can have multiple JRE versions on the same machine for different applications). The Series 60 Theme Studio installation package includes the JRE version it needs, but it can also be separately downloaded from http://java.sun.com/ (I don't remember what version is needed).
