can i install a software that will enable my n-gage to view themes?thankz...
can i?...or i can't?
Not really. Themes support appeared in Series 60 2nd Edition (2.0) and later (first phone with Themes was the Nokia 6600). The N-Gage is based on Series 60 1.2 (1st Edition).
You can get somewhat similar an effect with sLauncher (SmartLauncher):
http://www.symbianware.com/product.php?id=slauncher60&pl=n-gage
N/A wrote:Not really. Themes support appeared in Series 60 2nd Edition (2.0) and later (first phone with Themes was the Nokia 6600). The N-Gage is based on Series 60 1.2 (1st Edition).You can get somewhat similar an effect with sLauncher (SmartLauncher):
thankz...i don't think i'll get an answer if u weren't around..u're an n-gage genius!
hello.if u want 2 cheer up ur n-gage, why dont u install smart launcher. Its pretty good as u can manage ur own icon, how ur ngage look like.u also can create ur own skin using skin editor. its really fit me.
ohmlaw wrote:hello.if u want 2 cheer up ur n-gage, why dont u install smart launcher. Its pretty good as u can manage ur own icon, how ur ngage look like.u also can create ur own skin using skin editor. its really fit me.
thankz..can u tell me where to get it?
hi N/A.....is the smartlauncher that i got from the link that u povided already the full version or it's just a trial that has an expiry period?thankz....
Trial. You need to buy the full version.
