6630 turning itself off !! WTF !!
5 replies · 2,640 views · Started 27 May 2005
😡 ok heres the deal both myself and my wife have the 6630, ones on voda contract ( voda branded phone ) th eothers on vod payasugo ( non branded ) both just a little over 3 months old... no problems during that time, however they both randomly turn themselves off for no reason even with a fully charged battery and full sygnal strength 😮
any ideas why and how to cure, four times in an afternoon is a bit much
i have exactly the same problem with my voda 6630
as someone else mentioned in another thread, this could be happening when the 3G signal isnt strong enough and the phone keeps changing from 3G to GSM
i dont know if this is in fact fixed in the latest firmware, but its very annoying!
u need to upgrade ur firmware, it should be possible with any of ur network contracts. It happens because most likely ur phones are having the first firmware which is v 2. something.. It happens when ur phones switches between the GSM and the 3G areas, the phone does not have the ability to switch back and thereby gets stuck and issues such that u are talking about occurs..
This is the knowledge i've gathered from what i've read and heard.
Dang but at least u guys can use ur Nokia 6630's mine's locked to 3 and still cannot get it unlocked 😞
2PACroatia wrote:install nokia field test..and force it to gsm..
i have 2. something firmware..
everything works handy dandy..
What is "nokia field test"?
UA
i have just had my phone back from nokia for the second time, they didnt fix the issue with it switching itself off both times, and both times before i sent it off i asked for the LATEST firmware but twice it came back with the 2.39.x one which i told them was the first or at least the older one.
I phoned head office and mad a big fuss and they sent me a new phone, which thankfully had the new firmware (well newer) which is 4.03.18 . So far no problems 😃.
And at last my screensaver tells me when i have a message
