Boot problem
2 replies · 1,788 views · Started 27 May 2005
Just a quicky. I hope.
My N-gage (classic) will not startup with my 512MB Integral memory card inserted, unless I connect the charger. Doesn't matter how full the battery is, it will not boot up unless the charger is connected and switch on. This isn't a problem with other memory cards (I have a 128MB Kingston, original Sonic N and the Nokia Game thing), or with no card inserted. Different batteries don't seem to do the trick either.
Also, it's only a recent problem. I've had this card for about 3 months, and only in the last month has it done this.
It's probably something simple and obvious. It's not a huge issue, just an inconvenience when it dies (which it does) whilst at work for example. I hate not having MP3s on the bus ride home.
1. Have u check ur mmc 4 corrupt?
corrupted mmc fix
2. Can ur mmc detected by pc using data cable usb?
3. Boot in safe mode (hold edit/pencil key while ur phone is turn on)?
4. Restore the "factory settings"?
Enter the code *#7870# in ur phone
5. Hard format ur phone memory?
Enter code *#7370# in ur phone (remember, this could lost ur contacts, notes, messages, mail etc)-just back up it first.
6. Try using another phone?
7. What's in ur mmc? Apps? or have the apps with feature autoexec? Tell me.
8. What is the latest thing that u've done with ur mmc?
Wirelessly posted (Nokia3120/1.0 (05.30) Profile/MIDP-1.0 Configuration/CLDC-1.0)
If the your phone doesn't have any light on, i think you have to go to nokia repair shop.
