i cant delete it, why?
4 replies · 2,013 views · Started 27 May 2005
Hi guys,
i need help here.
I have transfer (i used bluetooth) a files basically it's .jpg file, but for some reason i cant delete it at all, everytime i delete it stays on inbox. i even restarted my 6600 but i still cant delete it. the message path is saved to my memory card.
Please help. Thank you.
Use one of file managers (e.g File manager) go to inbox mail wich you can find a shortcut to this folder if using my e.g prog, or you may go to e:\system\mail\... search the folders to finding your file! and just delete IT!
it's Finished!
i have SeleQ to user, i did what you said but stil i cant delete it. i mean i cant find the path to delete the jpg file.
what should i do?
Thank you man!
Try searching for the name of the file in the file manager. That should locate it.
If not look at the program Forward. That might let you move it out of the inbox / allow you to delete it.
