how to retrieve calendar details deleted from FExplorer???
1 replies · 2,519 views · Started 28 May 2005
Hi all, I'd tried to cut my calendar details from C drive and copied to E drive, not only it was not copied, all the details were gone too when I went back to C drive to check!!! 😡 Can someone teach me how to retrieve cos I have lots of important details in my calendar... I'd tried to search in FExplorer but it always hang and the screen just turned red! BTW, I'm using N6680. Thanks!
If the file has been deleted, it is gone and you can file this experience in your lessons learnt memories.
If you value your data more than you value the phone, a data recovery service like IBAS (http://www.ibas.com/) may be able to retrieve the data from the phone memory, but it is going to be expensive and without any guarantees (and in all likelihood a destroyed device, too). And if you've didn't immediately power off the phone, and continued its used, it is likely that something else has overwritten at least parts of the deleted file, so it is not likely to be completely recoverable at all no matter how much you pay.
Next time, I suggest you at least do regular backups. Minimally with the backup option of the "Memory" app, but also PC Suite (http://www.nokia.com/pcsuite). And it is also safer to synch calendar/contacts with Outlook or Notes (if you run them and Windows on your PC).
And, always make a backup before you try something you're not absolutely, completely sure about (especially with a tool like FExplorer with which you can do damage, if you you are not careful).
