6630 and Palm
2 replies · 1,396 views · Started 28 May 2005
Directly device-to-device? No (unless someone writes suitable software for them). You can send individual calendar entries from one to the other over Bluetooth (if you have a Palm with Bluetooth).
Or, you can synch the 6630 with Outlook on a PC using PC Suite. If you also sync your Palm with Outlook, then you are, in effect, linking the calendars through the PC/Outlook.
Yes the only way to do this is by going via a PC for a full sync, or indvidual items via Bluetooth. Symbianware make some programs that assist in multiple vCards over Bluetooth I believe.
The other thing to investigate woudl be doing this via SyncML over the air. Connect both devices to the same SyncML server (using the same account). Not sure whether this works with Palm or not.
