BT on 9300 - Receive only
3 replies · 1,671 views · Started 28 May 2005
[FONT=Verdana]Hello all,
I'm able to receive material via blutooth on my 9300, but whenever i try to send any single item ( < 100 KB) , i get this message:
"connection lost. some or all files were not sent' . :frown:
any suggestions.
Thanks in Advance[/FONT]..
abo_moaaz
Ismail wrote:what are u trying to send it 2?
make sure the other bluetoth deivce is fucntiong
the other device's BT is ok as it was used to send a jpg file to my 9300 and was successfuly recieved but when trying to resend it back to the sending device I get the error I earlier posted. btw, when you do search for devices and it shows a list , I assume each of these device's BT is active/on otherwise it wouldn't have been displayed. 🙄
abo_moaaz
yes ur right
i usually get the error message when the person is far away from me or he hits the dont accept button
