Wirelessly posted (Nokia N-Gage QD: NokiaN-GageQD/2.0 (4.00) SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
I need help with using my mmc card on my n-gage qd. I have a kingston 128 mb mmc card and when i put it in my n-gage i can use all of the games i have on it and listen to all the songs i have on it but about every 30 minutes or so it gives me an error that says "do not remove memory card without pressing power then remove mem. card", and then all of the programs i was running shut down. What do i do? Is there something wrong with my memory card or my phone? Somebody please help. Thanks!
It sounds like you have an error with the switch that tells the device there is a card in the device. You could probably check this by trying another card (of you have one)/
If you do a search of this forum you should find a previous post that references this problem where (I think) the recommendation was to check for the plastic tab that has something t do with the switch (sorry to be vague but I can't remember more).
Wirelessly posted (Nokia3120/1.0 (05.30) Profile/MIDP-1.0 Configuration/CLDC-1.0)
Veesonic wrote:Wirelessly posted (Nokia N-Gage QD: NokiaN-GageQD/2.0 (4.00) SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)I need help with using my mmc card on my n-gage qd. I have a kingston 128 mb mmc card and when i put it in my n-gage i can use all of the games i have on it and listen to all the songs i have on it but about every 30 minutes or so it gives me an error that says "do not remove memory card without pressing power then remove mem. card", and then all of the programs i was running shut down. What do i do? Is there something wrong with my memory card or my phone? Somebody please help. Thanks!
I think you should try change another of your mmc. If the new one is ok then it means that the error caused by your mmc and i think the best way is to format your card.
Thanks for the help. I'm going to back up my card on my computer and format it.
