I want to use Gmail On My Nokia 6680 i am using GPRS but want to use the
E-mail Function of my Phone.
Using Gmail On Nokia 6680?
Sure. Enable POP3 in GMail and use their POP3 settings (with your operators Internet Access Point): http://gmail.google.com/support/bin/answer.py?answer=13287
Choose "On (993/995)" for "Security (ports)" and "Off" for "APOP secure login"
Thanks a lot... outgoing mail dowsnt seem to work though
Try with your network operator's outgoing SMTP server (name or IP address).
When i connect Gmail via Gprs its say" Web connection time out"
When i say retrieve New Mail its connect to gprs and then say Server not Found
go into your access point settings, duplicate your current access point and edit it. There should be a field called "Access point". Change this to "internet" (small i!) Use this for gmail. For some reason i have to do this on mine
Vicky wrote:I want to use Gmail On My Nokia 6680 i am using GPRS but want to use the
Try to use the setup wizard...
like Apac nokia for 6680 there is setup wiz d/l it will help u to set up ur email easily. http://www.nokia.com.sg/nokia/0,,72768.html
international version is http://www.nokia.com/nokia/0,,71438,00.html
remember to select the correct service provider.
cheers
bjarke wrote:go into your access point settings, duplicate your current access point and edit it. There should be a field called "Access point". Change this to "internet" (small i!) Use this for gmail. For some reason i have to do this on mine
Hi am am having the same problem as Vickie, how do you duplicate your acess point ? I have tried and I cannot edit the access point.
