Im having a problem with setting the alarm clock volume higher.
When i set it in the clock>options>settings>ringtone (and you hear the example of the tone) its quite loud. When the alarm goes off its way, way quieter. Its almost overpowered by the sound of the vibration.
I also set the volume of the chosen profile to maximum (as mentioned in other posts).
Phone; nokia 6260, firmware; 3.0436.0
If anyone can help me out, a big thanks
EDIT; got it. Figured out that the alarm will increase in volume. When it repeats it starts at minimum, so the trick is to choose a large sound file like a miditune or mp3 so it can increase to maximum volume.
