problem converting files with smartmovie
3 replies · 1,834 views · Started 29 May 2005
after i conver the video file , i tried playing it with my mobile and my pc . The entire video jerks , including the sound . Anybody have any idea why i have this problem ?
Wirelessly posted (Nokia3120/1.0 (05.30) Profile/MIDP-1.0 Configuration/CLDC-1.0)
I think it has a problem with your codec of your phone or of your pc, mostly of the phone. My idea you should try reinstall smartmovie and codec in your phone. Make sure that the both of codec used in phone and in pc are the same. I've also ever had same problem, but i could fix it.
lightstarm2k wrote:Wirelessly posted (Nokia3120/1.0 (05.30) Profile/MIDP-1.0 Configuration/CLDC-1.0)
the thing is , whenever i play the file in my com after converting it . It keeps jerking , so the problem lies with the converter in my computer
