syncronisation pc - p910i
0 replies · 3,284 views · Started 30 May 2005
hia everybody,
i have big trouble syncing my p901 with outlook 2002.
I use the sync tool from the pc-suite (sonyericsson)...i start the sync..and
then there is a message coming up saying me...do you want allow the sync prog. to access outlook? i press "yes" for 10min. after this the sync continous..but it does nothing at all it tells my "initalizing started" thats it...what is wrong here..?
Do you have any other sync tools which works fine..?
thanks for your replys,
regards
adrian
