I hear somewere that i can connect it whit a audio output to my sterio system or speakers!? Is there someone hwo now is that posibal?
Can i connect my nokia 7710 with my sterio system???
i doubt it nokia seems to make only make mp3 phones with there own rubbish headphones. you can't even connect normal headphones unless you buy and adapter
You would need to buy an adapter to change the output to a normal output plug. Anything that has a line in should then be able to be used.
ths
