flight mode w/out sim directly & without 3rd party s/w
3 replies · 2,882 views · Started 31 May 2005
hey ppl! this was there in 6680 manual. is it there in 6630 too??
You can use your Nokia 6680 device without a SIM card.
Offline profile is automatically activated when the phone
is switched on without a SIM card. This allows you to use
the SIM card in another phone.
yes it does as thats what i with my 6630 as mine is on 3 and i have not got it unlocked yet so i keep my sim in another phone and use the 6630 for the cam, mp3 etc.
wow! that's simply gr8! can't wait to get hold on one. that means i can use d phone separately and use its features vitout inserting d sim! indeed gr8 thing. thanx a lot mate for that reply! i was really hoping that its there. and does anyone know the price of the nokia flash add-on?
cheers!! cya!
absi wrote:hey ppl! this was there in 6680 manual. is it there in 6630 too??
Sure you can, offline mode is available in the same way on the 6630 as is on the 6680. you can use your 6630 without a sim card in offline mode to transfer data to or from another divece, you can also activate it by pressing briefly the power button and scrroling to the offline mode, which is very handy on airplanes to to access yous files, music, camera etc.
