ogg player not playing tracks in order!!!!
2 replies · 2,204 views · Started 31 May 2005
I am not sure if it is me, but when I copy a cd to be converted to ogg files. I tick the tag box, but it seems to list and play tracks out of order on my phone(which is a N6680) Can someone guide me in the right directio please ! :icon14:
If you go to the track view it is out of sync but I've found that if you go to album view they are in the right order. But it depends on the info the tracks have been recorded with.
Check setup in options menu. If you have set SHUFFLE PLAY on secound positon it means that Oggplayer use this function. Push enter on it and change it into NORMAL PLAY. Mayby that was your problem.
