Hi All.
I wanted to know if the tom tom mobile 5 navigation kit is compatible with the Nokia 6630, if so is it available. Thank you in advance.
Hi All.
azzy wrote:Hi All.I wanted to know if the tom tom mobile 5 navigation kit is compatible with the Nokia 6630, if so is it available. Thank you in advance.
Hi darkshines6630.
Can I ask you where did you purchase your tom tom mobile 5 from and how much was it, as it is not available in the U.K.
azzy wrote:Hi darkshines6630.Can I ask you where did you purchase your tom tom mobile 5 from and how much was it, as it is not available in the U.K.
Sorry, not able to tell you if it is or where it is available. Someone I know had it on there mmc in 6630. So i gave it a try. like I say it worked great on both my phones. I will try to find out more about it for you
