P800 to P910 upgrade problem!
0 replies · 2,455 views · Started 02 June 2005
I just upgraded my trusty P800 to a P910i. I thought that data transfer would be no problem between the phones using backup and restore. However, when I connect the P910 and try to restore, the sync software will not recognize the backup file from the P800. Has anyone solved this problem? I really don't want to re-enter all my data.
Thanks,
PACRTG
