Favourites
14 replies · 3,372 views · Started 05 November 2002
Hi, I don�t know if this has been asked before. What I would like to know if they is a way to add more shortcuts in the Favourites Example: we have Calendar, Inbox and notes they can we add more? :-?
You can make bookmarks of pictures, sounds and other documents but
you cant make bookmarks of programs.
Hello Faraz,yes you can,with programs like task menager,i think that it can be done with the lates version of PSI NT's file menager,not sure dough.
it works easy with Taskman. of PsiLOC
i have my favorites full up,its much better to use the phone.
S�mi
[quote="S�mi"]it works easy with Taskman. of PsiLOC
S�mi[/quote]
im using seleQ and not intending to buy taskman, can i use their demo version, fill up my favorites, and then delete the app from the phone without moving back the progs i moved in the favorites folder?
[quote="GhostDog"]Hello Faraz,yes you can,with programs like task menager,i think that it can be done with the lates version of PSI NT's file menager,not sure dough.[/quote]
I installed PSI NT's file manager but doesn�t seem to be working for me, 😞 and I also tried Taskman, but that programs fucking hard to use I had to restart my phone :x . Dose anyone know any easier way. Please! :roll:
u definitely cant use fileman, i tried that one before, i copied a prog from Z: to the favorites folder and it wasnt moved - what's worse is i think i made a duplicate copy of that prog's folder without the actual prog moving and permanently lost about 40kb. havent tried taksman yet, according to sami it might just work.
Well,i did not think of copying the file,i thought that they had implemented the shortcut function in their new release,anyway,Taskmanager works for sure.
its easy to handel TaskManager.
Only instal it,then restart onces your Phone,
now add.the favorites.
then open in TM the options/tools/exit Taskmanager.
now he is passiv again,and u can remove him easy.
(only be shure,that he will be not active anymore,if u want to remove him)
This was one of firsts apps.i had on my phone:
and nothing bad happens,even i was really not so in it like i do know details of it now.
so,dont care and do it:
your phone will be happy....
S�mi
[quote="S�mi"]its easy to handel TaskManager.
S�mi[/quote]
thanks for the reply sami. couple more quick questions, if i install taskman, i can add more progs and apps in the favorites folder, right? this is what you're saying, right? if i uninstall it, will i still have the apps and progs in the favorites folder?
[quote="seanmiguel"][quote="S�mi"]its easy to handel TaskManager.
S�mi[/quote]
thanks for the reply sami. couple more quick questions, if i install taskman, i can add more progs and apps in the favorites folder, right? this is what you're saying, right? if i uninstall it, will i still have the apps and progs in the favorites folder?[/quote]
Yap,the shortcuts will stay if you delete taskmenager.
Cool ! 😃
What�s the easiest way to uninstall Task manger, because I had to restart my phone. :roll:
[quote="GhostDog"][quote="seanmiguel"][quote="S�mi"]its easy to handel TaskManager.
S�mi[/quote]
Yap,the shortcuts will stay if you delete taskmenager.[/quote]
thanks a lot!!!
