Bluetooth 6260 to PC dongle
2 replies · 2,266 views · Started 02 June 2005
I have a problem in that my Nokia 6260 seems UNABLE to send files via bluetooth to my PC (dongle). I tried it the other way round from PC to phone and that works.
Any ideas please are grately appreciated.
Rich
It probably isn't that the phone has problems sending things, but that your PC (its Bluetooth software) has trouble receiving. Check that whether there's something special you need to do for your PC to start receiving files over Bluetooth, or see if there is a newer version of Bluetooth software/drivers that work better.
If ur using plug and play, ul need to right clcik on the logo(in the systemtray) and chose recieve a file, and then send the file from ur phone.
