Text editor application wanted
2 replies · 2,603 views · Started 02 June 2005
Just wondering if there is a simple text editor type program available for the 6630. Something that can be used as a notepad when linked with a BlueTooth keyboard.
Thanks,
Rikki
Rikki wrote:Just wondering if there is a simple text editor type program available for the 6630. Something that can be used as a notepad when linked with a BlueTooth keyboard.
Thanks,
Rikki
There are quite afew availible including one just like xp notepad . You can also use the built in program. 😊
Do a search. www.my-symbian.com is also a good site.
