I've just bought a bluetooth usd adaptor mitsumi and I managed to send photos from my 7650 to my PC. But I still can't send files from outlook to PC. The nokia PC seems not to work with Bluetooth. If you have a other solution, tell me. Thanks.
Nokia 7650 Bluetooth and outlook
Verify that your adapter is Bluetooth v1.1 compliant, so to work with Nokia Data Suite. From NDS you can easy manage 7650 and Outlook contacts. I can't imagine any other solution 😮ops:
I try 3 different bluetooth solutions , all they didn't work with nokia connect data suite.
USB/COM/PCMCIA other then nokia PCCARD bluetooth perfectly work like virtual Serial/Dial-up adapter to phone. But sync addressbook/PC sync didn't see them. :-/
