and it says on 6630 that it is a 490MB card? is it like PC memory, you never get the actual full amount of memory?
also ordered a card reader to transfer files across but as luck would have it my standard card became currupted last night so all that data is lost I believe!
bradfordlad wrote:and it says on 6630 that it is a 490MB card? is it like PC memory, you never get the actual full amount of memory?also ordered a card reader to transfer files across but as luck would have it my standard card became currupted last night so all that data is lost I believe!
Don't you just hate that!!!
Could you possibly share with us where you got the card from and its cost?
u never get the advertised amount because memory manufacturers (every type of memory) measure 1000bytes to a kilobyte but operating systems measure them as 1024 so the bigger your memory you buy, the more u lose. yes everyone hates it. do they know we hate it? yes they do and they are happy too. will they change that in the future? i sure hope so but doesnt look too promising!
Meta I got it from mobilefun.co.uk
�79.99.
just trying to locate all the software that comes on the standard rsmmc now as mine got wiped.
Is it all available on the nokia site?
Hey,
A quick search on Ebay will find you some nicely priced 512mb DV RS MMC's.
One's at �66 inc. postage.
Finally they are coming and soon their price's will drop to.
The price of 256mb one's is very good now.
Ian
coolice wrote:Hey,A quick search on Ebay will find you some nicely priced 512mb DV RS MMC's.
Ian
yeh just got my 256mb one from ebay �22 inc delivery from hong kong 😊
