My 6600 has no voice output.
2 replies · 1,819 views · Started 03 June 2005
Hi there,
I managed to brake the handsfree pin inside my phone. Since then, although it doesn't show up as a handsfree is connected I get no output from the speaker when talking (the ring speaker on the back of the phone works just fine). So I assumed the problem was the broken bit in the handsfree hole, so I opened up the phone and removed it, but I still have the same problem.
I have since bought a new phone, but would like to fix this one so that I will have it as a backup.
Anyone have any clue what else I should check for?
Regards,
Michael
I sincerely think that you should have gone to a nokia service station straightaway after breaking your handsfree pin. But as you say that you have opned the phone yourself that means you have voided the warranty !!! But still I suggest to take your phone to a nokia service station. :icon14:
Well I had no warranty even before I opened up the phone (I bought the phone as soon as it came out, and that's much more than a year!).
I insist on fixing this phone on my own, it's a matter of self-respect!
Anyone knows how the handsfree detection circuit works?
Cheers...
