Need Help-Nokia 9300
1 replies · 1,535 views · Started 04 June 2005
:con? [FONT=Arial]This one is challenging. My Nokia 9300 internal screen is all white. The phone screen works fine and the it seems like the software internally and externally is working fine. I reset the phone and that did not work.
Anyone have any thoughts on this issue.
Thanks[/FONT]
crazyphones wrote::con? [FONT=Arial]This one is challenging. My Nokia 9300 internal screen is all white. The phone screen works fine and the it seems like the software internally and externally is working fine. I reset the phone and that did not work.
Thanks[/FONT]
do you recall last things done before this mishap, new software installed or sms attachment executed..etc to narrow probable causes. if after removing the battery & placing it back problem persists, i suggest you you take it to your friendly Nokia repairshop.
_____________________________________
dates on the calendar are closer than they look
