I am having trouble syncronizing Lotus Notes 6.5 calendar with Nokia 6670. I was able to sync 3 or 4 entries out of 20 or 30 only, and I am not getting an error message (just 'syncronization is finished"😉. Connecting via Bluetooth. All contacts have synced, no problem.
I am running Windows XP (SP2), LN 6.5, Nokia PC Suite 6.5 - all the good stuff.
I am totally lost .... please help!
Many thanks,
Veronica
vcharles wrote:Hi,I am having trouble syncronizing Lotus Notes 6.5 calendar with Nokia 6670. I was able to sync 3 or 4 entries out of 20 or 30 only, and I am not getting an error message (just 'syncronization is finished"😉. Connecting via Bluetooth. All contacts have synced, no problem.
Many thanks,
Veronica
Normally there is some error message in "view log" in PC Sync, but are you saying you are ot getting anything else than just "syncronisaiton is finished ?". Please view the log and see if there is some info.
What is the Bluetooth Sw you have in your PC ? Microsoft ? Or some other vendor ?
manta wrote:Normally there is some error message in "view log" in PC Sync, but are you saying you are ot getting anything else than just "syncronisaiton is finished ?". Please view the log and see if there is some info.What is the Bluetooth Sw you have in your PC ? Microsoft ? Or some other vendor ?
Sorry for being ignorant .... where do I find the log in PC Sync???
Bluetooth is Microsoft.
If you start the PC Sync app, the first/main dialog shown has a button with the descriptive title of "View Last Report", if it is of any help. 😉
Ok. When I check the sync status after the data is syncronised, the log just shows the nomber of updates made in Contacts, which is correct. No changes in Calendar are syncronised, just shows zero. No error message.
Looks like the calendar entries are just being ignored.
