HTTP connection / netcards.exe fails
2 replies · 2,211 views · Started 06 June 2005
Evening all,
I have troubles setting up emulator HTTP settings with 7.0s/Series60_v20 sdk (WinXP SP2). I followed the instructions in "Connecting_the_Symbian_OS_Emulator_to_the_Internet_using_Ethernet.pdf", but get stuck with the netcards.exe failure.
So if anyone could show the contents (even with example data) of the produced files: etherdriver.dat and ethermac.dat, i might be able to set up my system properly.. The files should be located in (e.g.): "C:\Symbian\7.0s\Series60_v20\Epoc32\wins\c\system\data\"
Thank you!
t,
tero
Where can I find "Connecting_the_Symbian_OS_Emulator_to_the_Internet _using_Ethernet.pdf".
Rashmi
