Attention 6681/6680 users !! (msgs vanishing from mmc)
0 replies · 2,254 views · Started 06 June 2005
i've recently bought a 6681... i've noticed a few problems.....
1) in case u are using mmc to store msgs then there will be times when on restart all the msgs will be lost mysteriously........ i've faced the problem 3-4 times and eventually had to switch back to phone memory for msgs..... formatting of both mmc and phone didn't solve my prob.... don't know what causes it, earlier i had a 6600 in which i used the same softwares as in this one, no problem there...........
using fexplorer and goin to mail folder on mmc u cannot open it properly...... guess the index gets corrupted!!
2) how to install slovoed dictionary? i already have pc suite installed.....will the 6600 version work?
3) there is a diffirence of half an hour in delivery reports from the actual time..... like in 6600 u cannot set the gmt offset to 00:00........
4) not a problem but a query, using the radio headset from nokia will i able to channelise the sound from phone's speaker?
i would greatly appreciate any feedback/solution to the same.........
Thx..........!!
