Create PDF files on your Nokia 9200 and your Psion PDA. mBrain Software has released PdfPrinter 1.00, for both the Nokia 9200 Series Communicator and for Psion and compatible PDA's.
With PdfPrinter you can create Adobe(R) Acrobat(R) files, also known as Portable Document Format (or PDF) files.
PdfPrinter is a printer driver, almost all programs that can print can now also create PDF files.
PdfPrinter can create PDF 1.2 (Acrobat 3.x), PDF 1.4 (Acrobat 4.x) and the latest PDF 1.4 (Acrobat 5.x) files.
Resulting PDF files are compressed for maximum storage utilisation and minimum transfer costs.
You can also encrypt files (including 128 bits encryption), set passwords and prohibit unathorised access and/or changes to the PDF file.
Included in the release is a version for the respective emulators, which means that you can create PDF files on your PC too.
PdfPrinter is available at http://www.mBrainSoftware.com
You can also download a demo version of PdfPrinter. The demo version will expire at 1 December 2002.
