Nokia 6600 and TomTom
4 replies · 5,572 views · Started 06 June 2005
I have got TomTom mobile and am trying to get it to work on Nokia 6600 with no success.
Basically, I have copied all the files/ directory to the MMC card but am unable to run anything.
This is the directory structure:
System
TomTom Mobile
2577
Benelux Navigator Map
System
TomTom
How can I get it to work? What file do I need to run? Do I need to 'install' or is copy sufficient? There isnt an install program
Any help would be appreciated
thanks
There is a file called 'TomTom Mobile.Exe' within the 'Tomtom' dir above.
Tom Tom were not very helpful as I would be using my own receiver that I bought from somewhere noy theirs.
When I run the exe on the phone its coming up with illegal format.
I didn't know you could buy it without a reciever ?
Just use the same directory structure from your original MMC, the program will appear just like any other installed app on your menu area.
just copy the whole tomtom mmc, dont use any folder names (ie, u call a folder tomtom and then open that folder and copy all files over)
but basicly u should just copy mmc to mmc and it should work, unless u got a "copy" then u might have problems
