Contact View that would let user select from a list of numbers
0 replies · 6,229 views · Started 07 June 2005
Hello Experts!
I would like to ask help..
I have here a code that would display the list of contacts from the phone memory.. however, i want to further enhance it.. the problem i with this code is that even though if a contact has many mobile numbers it would return immidiately the first which is +639201234567 (based from the example below).
ex:
Mobile Number: +639201234567
Mobile Number: +639179876543
i want it to display and enumerate the numbers of the contact, then the user will choose only one of them..
Here's the code:
void CQuickSMSContainer::PromptForContactL()
TInt aOk=0;
_LIT (KStringHeader, "\t%S\t\t"😉;
TBuf <60> aString;
TBuf <50> txtname;
TBuf <220> dummytxt;
TBuf <50> dummyphone;
// open the contact database
CContactDatabase* contactDatabase = NULL;
contactDatabase = CContactDatabase::OpenL();
// create an array to store the contact names
CDesCArrayFlat* itemArray = new (ELeave) CDesCArrayFlat(10);
// set the contact db view to look only at contacts (not groups)
contactDatabase->SetDbViewContactType(KUidContactCard);
// sort the contacts by last name and first name
CArrayFixFlat<CContactDatabase::TSortPref>* aSortOrder = new CArrayFixFlat<CContactDatabase::TSortPref>(2);
//CleanupStack::PushL(aSortOrder);
aSortOrder->SetReserveL(2);
TFieldType fieldType = KUidContactFieldFamilyName;
CContactDatabase::TSortPref::TOrder order=CContactDatabase::TSortPref::EAsc;
CContactDatabase::TSortPref sortPref1(fieldType,order);
aSortOrder->AppendL(sortPref1);
fieldType = KUidContactFieldGivenName;
CContactDatabase::TSortPref sortPref2(fieldType,order);
aSortOrder->AppendL(sortPref2);
contactDatabase->SortByTypeL(aSortOrder);
const CContactIdArray* iContactIdArray = contactDatabase->SortedItemsL();
iPbkContactEngine = CPbkContactEngine::NewL();
CPbkContactItem* contact;
if (iContactIdArray->Count() > 0) {
for (TInt i = 0; i < iContactIdArray->Count();++i)
TContactItemId Id = (*iContactIdArray)[i];
contact = iPbkContactEngine->ReadContactLC(Id);
HBufC* name=contact->GetContactTitleL();
dummytxt.Copy(name->Des());
if (dummytxt.Length()>50)
txtname.Copy(dummytxt.Ptr(),50);
else
txtname.Copy(dummytxt);
aString.Format(KStringHeader(),&txtname);
CleanupStack::PopAndDestroy(contact);
delete name;
itemArray->AppendL(aString);
if (itemArray->Count() > 0)
CAknSelectionListDialog* dlg;
TInt index = 0;
dlg = CAknSelectionListDialog::NewL(index, itemArray,R_LISTDLG_MENU_BAR);
dlg->SetupFind(CAknSelectionListDialog::EPopupFind);
if (dlg->ExecuteLD(R_CONTACT_SELECTION_LIST_DIALOG))
if ((index>=0)&&(index<itemArray->Count()))
const TContactItemId& choseContactId =(*iContactIdArray)[index];
contact = iPbkContactEngine->ReadContactLC(choseContactId);
HBufC* name = contact->GetContactTitleL();
nName.Copy(dummytxt.Ptr(),50);
else
nName.Copy(dummytxt);
TPbkContactItemField* phoneNumber=NULL;
phoneNumber = contact->FindField(EPbkFieldIdPhoneNumberMobile);
if (phoneNumber==NULL)
phoneNumber = contact->FindField(EPbkFieldIdPhoneNumberGeneral);
phoneNumber->GetTextL(dummyphone);
else
if (dummyphone.Length()>20)
nPhone.Copy(dummyphone.Ptr(),20);
else
nPhone.Copy(dummyphone);
phoneNumber=NULL;
delete name;
name=NULL;
aOk=1;
else
aOk=0;
else
aOk=0;
delete itemArray;
aSortOrder->Reset();
delete contactDatabase;
contactDatabase=NULL;
delete iPbkContactEngine;
iPbkContactEngine=NULL;
if (aOk==1)
nName.TrimRight();
nPhone.TrimRight();
//Name has been selected. Name and Number will be saved in nName and nPhone.
else
//contact selection canclelled
nName and nPhone are stored globally..
nName contains the name of the contact selected..
nPhone contains the number of the contact selected..
what should i add and where?
Tnx!!
