dust under screen
3 replies · 3,909 views · Started 07 June 2005
hi all, this is my first post so forgive me if it has been asked before but how do you take the cover off the 3230 as i have quite a bit of dust under my screen? chhers guys
Go check out the THread N3230 Dust I put in an explanation on how to get out the dust. It looks soooooo much better without dust 😎 😃
I also have the same problem of dust just inside my front LCD.
Also the'0' keypad button is quite loose & i bought da mobile jus 10 days back.
wats the reason that dust gets inside the panel.
pls reply????
