9210 profile problem.. pls help! thanks
5 replies · 3,620 views · Started 06 November 2002
i have this probelm regarding the 9210, whenever i go to (tel>settings>profiles) it gives me the following message "Note: unable to find the specified object" pls help me.... kinda need to set my profiles, did a format kasi but cant seem to somehow get that part right, did i miss on installing a certain software?
There is a profiles.SIS file, it might be worth re-installing this. It should be on your CD. My version is 3.01 (for a v4.13 9210).
Regards
thanks for all ur help, got it fixed already... upgraded my phone to version 4.13 before so i downloaded the stuff from the net for that version instead of using the ones that came with the cd.. it worked dunno lang if its because of the version incompatibility but if anybody gets the same prob. try wat i did 😊
Hi i just bought second hand nokia 9210 communicator, I am seeing this problem about the profile, cannot be found, also there are no games, nor ringing tones to choose from so I am thinking to reinstall the complete 9210 software. From where can I get it and do I install it from pc to 9210 via infrared?
Regards
Steve
