1. Is there an automatic key lock for the nokia 6620? Instead of pressing the power button, can it be done automatically, say after 10 seconds?
2. Is there a way to make the screensaver timer shorter? I want it to start running at 30sec instead of 1min.
3. is there a working remote control program for the 6620? I saw 2 for the 6600 but they dont seem to want to install...
EDIT: found KeyLocker for question 2. that did the trick 🙄
rai_dei wrote:1. Is there an automatic key lock for the nokia 6620? Instead of pressing the power button, can it be done automatically, say after 10 seconds?
http://www.symbian-freak.com/forum/viewtopic.php?t=350&highlight=jjlkeylockrai_dei wrote:2. Is there a way to make the screensaver timer shorter? I want it to start running at 30sec instead of 1min.
http://www.symbian-freak.com/forum/viewtopic.php?t=294rai_dei wrote:3. is there a working remote control program for the 6620? I saw 2 for the 6600 but they dont seem to want to install...
Total irRemote by PSI NT (Psiloc)
Total irRemote allows users to control their Audio/Video equipment with their mobile phone using built-in infrared port. It comes very handy when user wants to use one universal remote controller for all the devices instead of using few separate ones. Psi...
NoviiRemote by NoviiMedia
NoviiRemote for Nokia 6600/6620 turns your Nokia smartphone into an universal remote control. A lot of infrared codebases are included for popular home devices. NoviiRemote for Nokia 6600 & 6620 is a software program that provides a convenient means for c...
Both wprk on 6620 to, but with poor resualt, I mean phone has really weak IR transmiter
rai_dei wrote:EDIT: found KeyLocker for question 2. that did the trick 🙄
Well done 😉
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
[CENTER]
Symbian Freak introduces various researches for symbian users like:
Error Fixes, Modding, Guides, Tutorials and offcourse a detailed forum with professional support.
To get more out of your favourite device, visit the website.[/CENTER]
