Connecting to open WiFi networks
3 replies · 4,992 views · Started 08 June 2005
Hi all,
For some reason I'm unable to connect with my 9500 to open WiFi networks. I�ve no problem connecting to my wireless network at home.
Any ideas?
Thanks,
dovale
This is a detailed description of my problem:
I've problems connecting to open, i.e., free, without WEP security etc., WiFi networks. I can't figure out what I'm doing wrong or what I overlooked.
In Control Panel > Connections > Internet setup I select a given open network (for which I created an Access Point), then I choose 'Advance",
in IP configuration (IPv6DNS mode) I choose either DHCP or Well Known (which works to perfection on my home wireless network) - but neither of the two settings will allow me to connect to any given open network.
Any ideas anyone?!
Ciao,
dovale
I was having trouble connecting to some WiFi networks as well but found that if I turn off similtaneous bluetooth in the setup I connect fine.
I too have trouble connecting to some WiFi networks. At home and at a local bread shop it's fine. At some other locations I have to remove the battery, power-up, and then I can connect, but there are still a few areas that I cannot connect with the 9500. One of my favorite coffee shops is this way. So, I don't go as often. :frown:
Is there a firmware update that might fix this? And how do you know which firmware version you have?
