Group smsing not working
2 replies · 1,927 views · Started 09 June 2005
I used to use my 9210i to send group smses, ie write up one sms and send it to a group I created in my contacts.
I can't seem to do it with my 9500. I looked through the help file on the 9500 and it says it is possible but when I click on "recipient" in the sms my groups do not show.
Has anyone had any luck smsing to groups?
Ari
1. Create the group in Contacts
2. Goto to Contacts
3. Choose Menu, then go to Tools, then go to Settings
4. In Settings, go to the Advanced search tab and change the Group to Yes.
5. There will be a popup, saying that the options you turned on may not be optimized in performing search
6. Go back to message and create your text, once you look for the group in the recepient, you'll see the group name
This will make the search function slower when you locate a text recepient or search in the contacts itself
