MP3 ringtone/message tone
3 replies · 2,750 views · Started 09 June 2005
Hi all
I've managed to change my ringtone to an mp3 on my 6670 by opening it with RealPlayer, and selecting "Set as ringtone" in the menu there... is there any easier way of doing it?
Alos, there appears to be no way of setting the SMS message alert tone to an mp3; Is there actually no way to do this, or am I just being blind?
Thanks for your help,
Ben
themafia.69 wrote:profiles.
So I'm not that stupid.
I go Profiles -> Customise, and have a lovely list of options. If, however, I select "Ringing Tone" or "Message Alert Tone", I simply get a list of predefined tones. I can find no way in the Profiles section to set the either ringing or message tones to an mp3 I have put on the phone myself.
The *only* way I've found so far to set an mp3 as a ringtone is via RealPlayer, and I can find *no* way to set an mp3 as a message alert tone.
Hence my original question. Is it possible to set an mp3 as a message alert tone, and if so, please give me a step-by-step guide as to how. Cos I sure as hell can't find one 😛
galery > sounds > digital sounds (or simple)
you must put your mp3 or wav files in that folder, then you can go to profiles and select the tone directly without open the real player...
