how can i configure my email in secure outgoing mail server?
7 replies · 8,166 views · Started 06 November 2002
is there a way to confiigure my 7650 to send mail on a secure outgoing server? my mail server reuires smtp to be authenticated.
outgoing mail : mail.webfocus.ph
incoming mail : mail.webfocus.ph
on my recent mail server, it doesn't require any authenication and it works great, so could someone pls help me with my problem... thanks!!! :P
not sure if this helps but theres the option to enter a username and password in the email settings for each mailbox you set up.
There's also Secure (on/off) and Secure APOP (on/off) but I'm not sure what these do exactly.
Don't mean to take the P*ss but have you checked in your manual for email settings?
I got the same problem. But usually your Service Provider got a mail server you can set to use on outgoing mail. Since you usually connect through their network anyway - you can send through it, since send protection is normally only IP based.
The problem is that the Nokia 7650 does NOT support SMTP AUTH message.
Best
hello, to mj,,,
d ba tga pilipinas ka?
pano mo ba na set up ung mail box mo??
may bayad ba pag nag send ng email??
turuan mo na man ako o.. 😉
Yup! taga pinas me, what email account did you try to use???
from now, if ur a globe subscriber, the gprs is still free until further notice, no idea pa kung hangang kailan, if ur a smart subscriber, that is i dont know =o) so whats ur email account to be use???
