software for 6680
13 replies · 4,935 views · Started 10 June 2005
hi, just got nokia 6680. i want to know if smartmovie and sele Q can still work with 6680?
I am using Smart Movie and Its working fine and don't know abt Sele Q bcoz using Fx Exp.
Dear members,
I need help with 6680 PC Suite.
I had my 6680 for a month now and I use it mainly for work. My laptop has got built in bluetooth and got no problem connecting etc. However, although I tried 3-4 different versions of PC Suite I couldnt get the "messaging" to work.
The rest of the Suite works fine, but when I try to send a SMS via PC Suite a window pops up asking for "choose your phone" where my 6680 is greyed out. And you get stuck there.
Did you have anything like this? Could you help.
regards
Eddie
That text message editor in PC Suite needs a corresponding piece of software on the phone side for it to work. As things are now, such is not available for any Series 60 phones yet and that's why it doesn't work.
In other words, the text messaging feature of PC Suite works today only with Series 40 phones, but I'm pretty sure that'll change at some point.
A workaround, if you run Windows XP on your PC: Set up your phone to show up as a modem to Windows and search for and download "Microsoft SMS Sender" from Microsoft's web site.
smartmovie 2.73 works on 6680 no doubt BUT the movie stutters now and then in a while,geez.... 😎
i need 6600/6620/6630/7610 Asian _Opera 6.20 crack, can anyone tell me or tell me where i can find it
Hi there,
I'm new to smart-phones and Symbian stuff...
I see the Fexplorer at www.gosymbian.com - but what is it?! How is it different to the file manager that has come on my 6680?
Is there any other 'must have' SIS files that I should get?
Cheers - Jim Shady.
FExplorer allows access to every file + it has a bunch of additional built-in features (screen capture, set operator logo, etc.).
Oh right. Cool.
So once I've downloaded the file I use the USB cable to put it into my phone? And then I go to the file on my phone and execute it or soemthing?
Cheers - Shady.
I cant get smart movie to work on my 6680.
Try and open it, and nothing happens??
Anyone know where I can get the latest version??
N/A wrote:That text message editor in PC Suite needs a corresponding piece of software on the phone side for it to work. As things are now, such is not available for any Series 60 phones yet and that's why it doesn't work.
The latest version of PC Suite now has this feature 😊 😊 😊
