my phone is sometimes rebooting by itself and I have to start call recorder manually again, what files do I have to edit and make to start this application automaticaly whenever my phone powers up ?
program auto start-up ?
almazlamaz wrote:Hi,
Autostart by Anatra
AutoStart application is a simple but useful tool for every Nokia 7650/ 3650 user, which gives a similar functionality to the Windows Autostart folder. Every time you switch your phone on, selected applications will be started automatically for you. ...
Autoexec by Avista
"Autoexec" for Nokia 3650/7650 allows you to create a modifiable list of applications that will be started after every phone reboot. For example, you can include "Answering Machine" into the list and it will be started automatically every time you're turn...
And so long....
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
[CENTER]
Symbian Freak introduces various researches for symbian users like:
Error Fixes, Modding, Guides, Tutorials and offcourse a detailed forum with professional support.
To get more out of your favourite device, visit the website.[/CENTER]
I already tried these two before, non of them works on my nokia 6600.
are here any other similar programs ?
or is here any way to do it manualy ? edit some start up file ?
Are u sure!?!!
What about!?
AutoExec by SmartAppz & SymbianWare
Start your favourite applications and documents automatically. With the help of AutoExec you can define the list of applications, exe-programs and documents that need to be launched when the phone is loading. ...
Cheers,
Apoc
[CENTER]
[CENTER]
Yes I'm positive,
woudl you answer my question please 😊
