Ultimate Nokia S60 tutorials and help
3 replies · 50,600 views · Started 10 June 2005
  • Question: How to full format your Symbian S60 phone [Answer]
    Question: How to connect via IR [Answer]
    Question: Solving jar = zip problem in Windows [Answer]
    Question: How to get most space on your mmc
    Question: Save memory when installing apps, by installing over bluetooth [Answer]
    Question: How to heck if the recepients phone is on [Answer]
    Question: How to rotate image viewing a picture in your phone's gallery [Answer]
    Question: Difference between A soft and Hard reset [Answer]
    Question: Supported formats of images [Answer]
    Question: How to copy & paste text in your Nokia [Answer]
    Question: How to turn on/off the "click" sound made by the camera [Answer]
    Question: How to change background image [Answer]
    Question: How to display an image when someone's calling[Answer]
    Question: How to add a personal ringing tone to a contact [Answer]
    Question: How to send or hide your caller ID[Answer]
    Question: How to make your Nokia 7610 work with regular sized MMC [Answer]
    Question: Detailed code list for your Nokia [Answer]
    Question: How to install Java and Applications Tutorial [Answer]
    Question: Nokia N-Gage and N-Gage QD
    [list]Question: [Answer]
    Question: What's the difference between the N-Gage and QD? [Answer]
    Question: Which N-Gage is better? [Answer]
    Question: Can my (input s60 phone here) play N-Gage games? [Answer]
    Question: How do I check firmware and IMEI on my N-Gage/QD? [Answer]
    Question: How do I change my operator logo for my N-Gage/QD? [Answer]
    Question: How do I change my wallpaper on my N-Gage/QD? [Answer]
Question: How to convert MP3 to truetone AWB or AMR file [Answer]
Question: How to use your pc connection on your Symbian S60 device [Answer]
Question: How to copy Files From PC To Phone [Answer]
Question: How to install Files on your Symbian S60 device [Answer]
Question: How to uninstall Files on your Symbian S60 device [Answer]
Question: How to use Gmail On Your Mobile [Answer]
Question: How to set Bluetooth Connection from your mobile to your pc [Answer]
Question: Explaining Nokia Phone series
  • Question: [Answer]
    Question: What represent the first number in my phone's name [Answer]
    Question: What are main official Nokia resources [Answer]
    Question: Where to find info about Nokia Phones and company [Answer]
    Question: Which phonemanagers are good [Answer]
    Question: What does series XX represent [Answer]
    Question: SMS tips for Nokia series 40 [Answer]
    Question: How to turn t9 off / on [Answer]
    Question: All nokia phones with band and software version
    [list]Question: GSM 900 or 1800 [Answer]
    Question: GSM dual band 900/1800 [Answer]
    Question: GSM Triband 900/1800/1900 [Answer]
    Question: Nokia UMTS 2100 [Answer]
    Question: Nokia Communicators [Answer]
    Question: Nokia Cardphones [Answer]
    Question: Nokia Carphone [Answer]
[/list]
Question: How to shorten (truncate)MIDIs [Answer]
Question: Drives on symbian phones [Answer]
Question: How to clear SMS reports [Answer]
Question: Problems with sending files from 7650 to PC via BT [Answer]
Question: Tutorial on making your own True Tones mp3 format [Answer]
Question: How to create .3GP (convert avi, mpg to .3gp file) [Answer][/list]
  • [Answer]
    Question: Explaining filetypes we use here (.sis, .jar, .rar, .zip, .ace) [Answer]
    Question: Where are the files that you send to your phone via IR or BT?* [Answer]
    Question: N-gage games explained [Answer]
    Question: How to connect your Nokia Series 60 device via Bluetooth [Answer]
    Question: How to manually make a serial connection to the Series 60 Handset to get the mRouter connection started [Answer]
    Question: How to make or change operator logo [Answer]
    Question: How to install applications/games (.sis/.jar files) on Ngage [Answer]
    Question: How to delete files in your inbox you can't delete normal way [Answer]
    Question: How to backup your phone on mmc [Answer]
    Question: How to change storage for your sms messages [Answer]
    Question: How to remove operator logo [Answer]
    Question: The ultimate guide to get a cracked .app file on your Symbian S60 device [Answer]
    Question: How to fix "App. Closed Main" error [Answer]
    Question: How to convert iTunes music library into a format that you can play from your mobile [Answer]
    Question: Tips / undocumented functions:
    [list]Question:* [Answer]
    Question: Easy moving thru menus [Answer]
    Question: Why left menukey in standby-mode takes more to open than right [Answer]
    Question: How to switch from text to numbers while typing [Answer]
    Question: How to launch your wap home page from stand-by [Answer]
    Question: How to turn on light without unlocking your phone [Answer]
    Question: How to keep backlight always on [Answer]
    Question: How to check your firmware version [Answer]
    Question: How to check your IMEI (International Mobile Equipment Identity) [Answer]
    Question: How to check your Bluetooth device address* [Answer]
    Question: How to format the phone memory [Answer]
    Question: How to call specific number on your sim in memory slots [Answer]
Question: Repairing A Corruptted MMC & Correct Treatment of your MMC [Answer]
Question: FExplorer Tips & Tricks
    Question: How to reset the operator logo [Answer]
    Question: How to make a screenshot on a Nokia S60 [Answer]
    Question: How to make a screenshot on a Siemens SX1 [Answer]
    Question: Some shortcuts for users [Answer]
    Question: Why 'send command' fails new firmware [Answer]
Question: Can't Uninstall Applications via Manager?* [Answer]
Question: What when phone hangs on Start-up [Answer]
Question: Operator Logos Explained [Answer]
Question: How to transfer Mp3s[Answer]
Question: Mp3 as ringtones for the 6600? [Answer]
Question: How to install and use new fonts on Symbian S60 phone [Answer]
Question: Disassembly info for Nokia 6600 [Answer]
Question: How to take Phone ScreenShots [Answer]
Question: How to Speed up 6600 [Answer]
Question: How to free more RAM on your phone [Answer]
Question: Do u know how to use the edit button (abc or pencil button)? [Answer]
Question: How to avoid being blue jacked [Answer][/list]
  • Question: How to backup one MMC to another MMC [Answer]
    Question: How To View Hidden Files in MS Windows [Answer]
    Question: Installation procedure for DKU-5 cable [Answer]
    Question: Series 40: I've installed a game and it is not fullscreen. Can it be fixed? [Answer]
    Question: Series 40: What size can app/games are? [Answer]
    Question: Series 40: I want install a sis-file, how it's done? [Answer]
    Question: Series 40: Where do I get a blank operator logo? [Answer]
    Question: Can Series 40 Games be played on Series 60 phones? [Answer]
    Question: I've bought a cable for my phone but it won't work. Why? [Answer]
    Question: Where are my messages saved? [Answer]
    Question: I've formatted my MMC with a card reader, now I can't access the card with my phone. What now?* [Answer]
    Question: Where to put my ringtones? [Answer]
    Question: How do I install an app/ a game? [Answer]
    Question: Which Symbian OS version does my phone use? [Answer]
    Question: How can I upgrade my Symbian OS to a newer version? [Answer]
    Question: Nokia 6230: When I want to upload something on the MMC I get a "The operation could not be completed" error. How to fix this? [Answer]
    Question: Nokia 6230: Can I use mp3s as ringtones? [Answer]
    Question: Nokia 6230: I've got a big movie on my phone and want to fastforward (rewind). How can I do this? [Answer]
    Question: Nokia 6230: I've uploaded mp3s to my MMC and arranged them in folders. The phone won't find any of them. Can this be fixed? [Answer]
    Question: Deleting leftover Game/App Icons [Answer]
    Question: Simple Task Manager for Symbian S60 phones [Answer]
    Question: How to connect your N-Gage to your PC [Answer]
    Question: Some usefull N-gage tips:
    Question: Using USB cable without MMC [Answer]
    Question: Using memory cards on your N-gage [Answer]
    Question: Working with 7650/3650 appz and games [Answer]
    Question: Is there a camera for N-gage? [Answer]
    Question: Can I use larger MMC than 128 [Answer]
Question: Series 60 FAQ: E-Mail Issues [Answer]
Question: Email issue: Error Message: General System Error. [Answer]
Question: Able to receive but not send email. [Answer]
Question: Can I automatically check my email every x minutes? [Answer]
Question: How to use Linux on Symbian phones [Answer]
Question: Memory Cards: Can I use SD cards with my phone? [Answer]
Question: Memory Cards: What size of MMC cards are supported? [Answer]
Question: Memory Cards: What can I store on my MMC? [Answer]
Question: How to 6600 and iSync [Answer]
Question: More tutorials to come soon![/list]
What else can I find on this forum?
Symbian All Freeware collection - [here]
Disassembling all Nokia phones - [here]
Download Manuals for all phones! Both Serbian and English
  • All available manuals for Nokia phones - [here]
    All available manuals for Siemens phones - [here]
    All available manuals for Alcatel phones - [here]
    All available manuals for Ericsson phones - [here]
    All available manuals for LG phones - [here]
    All available manuals for Mitsubishi phones - [here]
    All available manuals for Motorola phones - [here]
    All available manuals for Panasonic phones - [here]
    All available manuals for Samsung phones - [here]
    All available manuals for Philips phones - [here]
    All available manuals for Sagem phones - [here]
    All available manuals for SonyEricsson phones - [here]
    All available manuals for Sony phones - [here]
    All available manuals for Sendo phones - [here]
    All available manuals for Benefon phones - [here]
    All available manuals for Bosch phones - [here]
Hi all,
I am trying to display a transparent bg png image on the s60 emulator screen. It works if i just creating the raw image and display it. However, i need to resize the image, so if i resize the raw image and display it on screen, i will get a white background where it should be transparent..
So far i have tried a few ways to solve the problem.
<code>
//create a mutable image
Image img = Image.createImage(width,height);
Graphics g = img.getGraphics();
//set some color that you know you aren`t going to use
g.setColor(0x123456);
g.fillRect(0,0,width,height);
//this is where you draw the things that you want into g
/* remember that if you are drawing an image into this graphics, it must have
* the same color that you selected before(ie 0x123456 ) as a background
*color in order to become transparent later
//convert that image into a bytearray
byte[] byteArray;
img.getRGB(byteArray,0,img.getWidth(),0,0,img.getWidth(),img.getHeight());
//replace the color that you had put before for a transparent pixel
for(int i=0;i<byteArray.length;i++){
if(byteArray[i]==0x123456){
byteArray[i]=0x00000000;
//and then create the image with a transparent background
img=Image.createRGBImage(byteArray,witdh,Height,true);
</code>
But it didnt work...the bg color will jus remain as the 1 i set earlier on..
Any solution to my problem??
