nokia 6600 contacts on mmc
6 replies · 5,024 views · Started 13 June 2005
Hi All,
Is it possible to put the contacts in 6600 to the mmc card.
I could not find any thing to do it.
I was able to do it for the messages but not for contacts.
is it even possible ?
Abhishek
will it just copy from phone memory to mmc or will change the settings so that all new contacts will be stored on mmc.
hi there,
how were you able to copy your messages to the mmc? from that time on did all your messages got stored in the mmc?
cheers,
Look up the "Memory in use" option under Messaging > Options. Your choices are "Phone memory" or "Memory card".
thanks.
can contacts and calendar entries be copied to the mmc as well? can i move this to my 3230?
thanks again in advance 😊
stitch626 wrote:thanks.
calendar? i dun know.
but for contacts, u can use some applications such as SV Card, etc.
