Handy Safe solution now in beta
0 replies · 2,165 views · Started 15 June 2005
Epocware have started up the beta program for the full Handy Safe system (i.e. PC client syncing with Communicator app) for the Nokia 9300/9500. Even better, using their standard import/export format, you can move across all your old Nokia 9210 Handy Safe data, with 100% success rate. You can join in the beta here.
