Send Data to your series 60 without using Bluetooth, Cable, GPRS or IR
3 replies · 2,715 views · Started 15 June 2005
is this real? not too keen on allowing random site access to a file on my pc....
I still think it s p*ss take every time i read it!
most likely this is for real.
I once had a Timex Watch that did the same trick (although a bit more primitive).
You had to hold it about 30 cm in front of a monitor and then a build in sensor was used to read the flashing blocks that contained your updated adresses and apointments.
http://www.geocities.com/SiliconValley/Garage/7926/m70.htm
It remains weird though that only a web based sender is available.
As it dous not really has anything to do with FTP or even internet at all.
You just need a program that coverts the data you want to send into a form of barcode (here collored blocks are used). and a piece of sofware on your mobile that uses the camera to covert these barcodes back into usable data.
