Looking for 'seahorse.mid' ringtone
15 replies · 11,173 views · Started 15 June 2005
Hi there,
I have a 6681 & the Seahorse mid you want, but bein a bit of a newbie i can't figure out how to send it to you. Its listed on my profiles ringtones but not under my sounds. If you can send me instructions on how to do it i will
Cheers Gail 😊
gail1160 wrote:Hi there,
Cheers Gail 😊
use FExplorer and then send it to ur pc via buetooth.
if u manage to get it , send to me as well , don't know how it sound like
[email][email protected][/email]
thanks
lil more detailed than that he wont know, u will have to use fexpolrer and go to the z drive, thats the rom (read only memory) for the phone where all the ringtones that come with it and all the factory settings are stored so if u format your phone (*#7370#) it will be in z:\->Nokia->sounds->digital
copy it to another directory and rename the new file to Seahorse.mid0, then send it to your pc over bluetooth and rename it to .mid on the PC.
Hi there
I have been trying to copy my ringbones onto my new memory chip but it won't let me. As a result I have lost all the ring tones I really like.
Seahorse
Soul
I would be grateful if you could send these to me and also let me know how to transfer them to my memory card.
Many thanks
Jaybeezee
