how to I install a game on my ngage!?
installing games
- Download it from a server directly to your phone using the phone's browser
- Send it to your phone over Bluetooth and open it from your inbox
- Send it your phone as an email attachment
- Use PC Suite Application Installer to install it
- Put it on the memory card (with the USB cable, if you have an original N-Gage, or a PC based card reader otherwise) and use the "Manager" app to install
- Read the User's Guide of the phone
- Learn to use the search feature of this site: http://www.allaboutsymbian.com/forum/search.php?
somebody told me I could use some kind of copy/paste method and it would be easier. can`t I do that insted!?
eh, I succeded in installing a game but now I don`t know how to delete it, tried using "c" and deleting from FExplorer but it still remains in roots meniu and the mmc is still full, what should I do!?
Use the "Manager" app to remove (Options > Remove) Symbian/Series 60 programs (works also for Java apps on phones based on Series 60 2nd Edition, 2.x or later; the N-Gage is based on 1.2), and for Java apps menu -> Extras > Applications (& Options > Remove).
More details in the User's Guide (which you can read online or download a PDF file on http://www.n-gage.com/en-R1/support/).
N/A wrote:Use the "Manager" app to remove (Options > Remove) Symbian/Series 60 programs (works also for Java apps on phones based on [FONT=Arial]undefined[/FONT]Series 60 2nd Edition, 2.x or later; the N-Gage is based on 1.2), and for Java apps menu -> Extras > Applications (& Options > Remove).More details in the User's Guide (which you can read online or download a PDF file on http://www.n-gage.com/en-R1/support/).
n/a how to add or save mp3 sound as ringtones.thanx!
N/A wrote:Use the "Manager" app to remove (Options > Remove) Symbian/Series 60 programs (works also for Java apps on phones based on Series 60 2nd Edition, 2.x or later; the N-Gage is based on 1.2), and for Java apps menu -> Extras > Applications (& Options > Remove).More details in the User's Guide (which you can read online or download a PDF file on http://www.n-gage.com/en-R1/support/).
n/a how to copy e:files to c:files since i want to copy the sounds or ringtones from e:drive w/c is mmc to my device c: phone memory as you said.
n/a how to copy E:files(mmc files) to C:drive w/c is phone memory since i want my sounds or ringtones to put in my device.how to use FExplorer to transfer these things.
Use FExplorer (http://www.gosymbian.com) to copy files on the phone (and a lot of other things).
MP3 files should be in c:\Nokia\Sounds\Digital in phone mem and e:\Sounds\Digital on the memory card to be used as ringing tones.
