Insert Contact Phone Number in SMS
4 replies · 3,129 views · Started 15 June 2005
Hi, I have searched through the forum but can't find an answer to what's bothering me on my 7610... hope someone can help 😊
I've always had Nokias and on all previous models I've been able to insert a contact's phone number into the body of an SMS text message (usually using the 'Insert Contact' option on the menu), however on the 7610 this option doesn't seem to be present - is there any way of doing this?
thanks in advance for your help! 😃
It, indeed, is a missing, but would be nice to have, feature of the Messaging app on Series 60 based phones.
Workaround:
- While writing a message, hit the menu key to switch away from the Messaging app (but leaving it running in the background),
- start the Contacts app,
- find the contact you want,
- open the contact, choose "Edit", choose the number field you want,
- press down the "pencil" key and keep it down & use the left arrow/directional key to select the number and choose "Copy"
- now a long press of the menu key will bring up a list of running apps, including "Messaging", which you select from the list (with the center press of the directional key)
- then when back in the message editor, press and hold the "pencil" key again and choose "Paste"
liz999 wrote:Hi, I have searched through the forum but can't find an answer to what's bothering me on my 7610... hope someone can help 😊
N/A wrote:It, indeed, is a missing, but would be nice to have, feature of the Messaging app on Series 60 based phones.
Workaround:
